Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 7 guías que incluyen este paso.
Inglés
Español
Paso 2
Turn the device so that the underside faces you, and the edge where the case and device bind, faces upward. The opening of the device should be face down. In this position you will see a crease line between the device and the top cover. Gently Insert your blue plastic opening tool into the crack of the crease line, between the front and back cover to separate them.
  • Turn the device so that the underside faces you, and the edge where the case and device bind, faces upward. The opening of the device should be face down.
  • In this position you will see a crease line between the device and the top cover. Gently Insert your blue plastic opening tool into the crack of the crease line, between the front and back cover to separate them.
  • Be careful when separating the front and back covers, as the two are held together by a thin wire.
  • Separate the halves of the case.
Insertar traducción aquí
