Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 3
I find it easiest to prop up the top shell on the front right corner of the system. If you're using a flat surface it can stand by itself and there's enough slack in the Genesis PCB and Dial Switch cables to allow it to be positioned in such a way.
Remove screws securing the PCBs to lower shell
  • I find it easiest to prop up the top shell on the front right corner of the system. If you're using a flat surface it can stand by itself and there's enough slack in the Genesis PCB and Dial Switch cables to allow it to be positioned in such a way.
  • You can barely see it but the upper shell is standing upright on the front right corner.
  • There are 11 screws that need to be removed in order to remove the entire PCB unit.
  • If the IR lens cover pops out at this point don't worry about it. It can be easily reinstalled during the reassembly process.
Insertar traducción aquí
