Saltar al contenido principal
Inglés
Español
Paso 2
If there are any screws fastening the door's handle to the inside panel, remove them. Remove the door handles. You may need to insert a flathead screwdriver between the handle assembly and the panel.
Remove Handle
  • If there are any screws fastening the door's handle to the inside panel, remove them.
  • Remove the door handles.
  • You may need to insert a flathead screwdriver between the handle assembly and the panel.
  • When removing the handle assembly, push towards the inside of the car door to remove the handle from its left-side clips.
  • Use your fingers or a screwdriver to unclip the handle's push rod from the handle assembly.
Insertar traducción aquí
