Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
Pull on the hood release lever just inside the driver-side door to pop the hood. Locate the hood release latch under the hood. Use one hand to press up on the latch while you lift the hood. Insert the hood prop rod into the hole in the hood marked with an arrow.
Opening the Hood
  • Pull on the hood release lever just inside the driver-side door to pop the hood.
  • Locate the hood release latch under the hood. Use one hand to press up on the latch while you lift the hood.
  • Insert the hood prop rod into the hole in the hood marked with an arrow.
Insertar traducción aquí
