Saltar al contenido principal
Inglés
Español
Paso 13
Locate the window washer fluid reservoir in the front right corner of the engine bay. If the fluid level appears to be low, refill the reservoir with window washer fluid.
Window Washer Fluid
  • Locate the window washer fluid reservoir in the front right corner of the engine bay.
  • If the fluid level appears to be low, refill the reservoir with window washer fluid.
  • You can also use a mixture of water and generic window cleaner, such as Windex. Use a ratio of 5 parts water to 1 part window cleaner.
Insertar traducción aquí
