Saltar al contenido principal
Inglés
Español
Paso 12
Twist the oil filler cap counterclockwise, and remove it from the top of the engine. Using a funnel, pour one quart of manufacturer specified oil into the engine. Your engine may take different oil depending on the manufacturer specification. Check your owner's manual.
  • Twist the oil filler cap counterclockwise, and remove it from the top of the engine.
  • Using a funnel, pour one quart of manufacturer specified oil into the engine.
  • Your engine may take different oil depending on the manufacturer specification. Check your owner's manual.
  • Remove the dipstick and check the oil level.
  • If the oil level is still low, add more oil.
  • Be sure to not overfill the engine. After adding the first quart, check the oil level every half-quart.
  • When the oil has reached the proper level, replace the dipstick and oil filler cap.
Insertar traducción aquí
