Saltar al contenido principal
Inglés
Español
Paso 4
Scrape the corrosion off of the battery terminal using a wire battery brush or some other scraping/brushing tool. You may want to avoid getting the corrosion all over the inside of the engine bay. Sweeping the corrosion onto a paper plate or rag is a simple way to get the corrosion out of the engine bay without making a mess.
  • Scrape the corrosion off of the battery terminal using a wire battery brush or some other scraping/brushing tool.
  • You may want to avoid getting the corrosion all over the inside of the engine bay. Sweeping the corrosion onto a paper plate or rag is a simple way to get the corrosion out of the engine bay without making a mess.
Insertar traducción aquí
