Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 19 guías que incluyan este paso.
Inglés
Español
Paso 4
Use your fingernail to flip up the retaining flap on the keyboard ribbon cable ZIF socket. Be sure you are prying up on the hinged retaining flap, not the socket itself. Use the tip of a spudger to pull the keyboard ribbon cable out of its socket.
  • Use your fingernail to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
  • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  • Use the tip of a spudger to pull the keyboard ribbon cable out of its socket.
  • The cable may be difficult to insert. If you are having trouble, temporarily attach a piece of tape to the cable to help you guide the cable into the socket.
Usa la uña para voltear la solapa de retención en el zócalo ZIF del cable plano del teclado.
Asegúrate de que estés empujando hacia arriba en la solapa de retención con bisagra, no la toma en sí.
Utiliza la punta de un spudger para sacar el cable plano del teclado su zócalo.
[* black] Use your fingernail to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
[* icon_caution] Be sure you are prying up on the hinged retaining flap, '''not''' the socket itself.
[* black] Use the tip of a spudger to pull the keyboard ribbon cable out of its socket.
[* icon_reminder] The cable may be difficult to insert. If you are having trouble, temporarily attach a piece of tape to the cable to help you guide the cable into the socket.
