Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 7 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Insert an opening pick between the rear case and the plastic rim. You may need to add multiple picks to detach the clips.
  • Insert an opening pick between the rear case and the plastic rim.
  • You may need to add multiple picks to detach the clips.
  • Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
  • Continue to slide the pick around the edge of the rear case until all clips are released.
Insertar traducción aquí
