Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 7 guías que incluyen este paso.
Inglés
Holandés
Traduciendo paso 1
Paso 1
Insert an opening pick between the rear case and the plastic rim. You may need to add multiple picks to detach the clips.
  • Insert an opening pick between the rear case and the plastic rim.
  • You may need to add multiple picks to detach the clips.
  • Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
  • Continue to slide the pick around the edge of the rear case until all clips are released.
Insertar traducción aquí
