Saltar al contenido principal
Inglés
Español
Paso 2
Connect Switching module BLUE wire into Pin 17 on the BLUE plug on your TV video module. Slide the Black Locking lever to the side on your TV video module to release the Blue plug. Remove the cover of the blue plug by gently lifting up on the cover locking tab with a small screw driver.  Then slide the cover off
  • Connect Switching module BLUE wire into Pin 17 on the BLUE plug on your TV video module.
  • Slide the Black Locking lever to the side on your TV video module to release the Blue plug.
  • Remove the cover of the blue plug by gently lifting up on the cover locking tab with a small screw driver. Then slide the cover off
  • Insert the BLUE pin into the Pin location 17. If you look closely you will see the number 18 on the black part of the plug. Pin 17 would be the next pin location over
  • PLEASE NOTE: IF your camera switch module has an extra wire in the center marked 87a it is NOT connected anywhere. This extra wire, if present, is not used.
Insertar traducción aquí
