Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 3
This method copies the driver files to your computer. If you connect a new printer and don't install the printer specific driver, this can be used in place of that driver. At the installation screen, select USB mode- Plug and Play. Once you select the mode, pick the options you wish to use. While these settings can be changed, they should be left alone unless you understand what you're doing.
Driver installation (USB Mode)
  • This method copies the driver files to your computer. If you connect a new printer and don't install the printer specific driver, this can be used in place of that driver.
  • At the installation screen, select USB mode- Plug and Play.
  • Once you select the mode, pick the options you wish to use. While these settings can be changed, they should be left alone unless you understand what you're doing.
  • Click Next and the files will be copied to your computer.
Insertar traducción aquí
