Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
Turn OFF Car.
  • Turn OFF Car.
  • Turn ON high Beam headlights for 5 minutes. This removes the surface charge for proper testing.
  • Turn OFF High Beam headlights.
  • Press and hold the Check Control button in the instrument cluster (RIGHT button), and turn the ignition key to the first position (KLR).
  • You will first see "Check Control OK", some seconds later you will see "Test Nr.01".
  • Select Test Number 1. by Pressing the left button on the instrument cluster to see the car's identification number. Add the 5 digits (not 6)
Insertar traducción aquí
