Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 5 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Using the flat end of a spudger, pry the subwoofer connector straight up off the logic board.
Optical Drive
  • Using the flat end of a spudger, pry the subwoofer connector straight up off the logic board.
  • On some models, the subwoofer connector is soldered to the logic board and will break if you pry it off. If you need to replace the speaker/subwoofer, you can pull back the foam padding on the connector and remove the red and black wires to disconnect. You will need to reinsert the wires from the new speaker to reconnect.
  • If you are only removing the optical drive and not replacing the speaker/subwoofer, you do not need to disconnect this connector.
Insertar traducción aquí
