Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Traduciendo paso 19
Paso 19
Connect both the SATA data and SATA power connectors to their respective sockets on the SSD. Peel the backing off of the double sided tape. Carefully set the SSD into the iMac optical bay as close to the lower left corner as possible.
  • Connect both the SATA data and SATA power connectors to their respective sockets on the SSD.
  • Peel the backing off of the double sided tape.
  • Carefully set the SSD into the iMac optical bay as close to the lower left corner as possible.
  • Do not repeatedly stick and un-stick the tape, as the adhesive will become weaker.
  • Once you are happy with the SSD's placement, firmly press down along its edges to ensure full adhesion.
  • When re-installing the optical drive, the SATA cable will be sandwiched between the foam padding and the optical drive.
Insertar traducción aquí
