Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 14 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 8
Paso 8
Lay the display face down on a flat, soft surface.
  • Lay the display face down on a flat, soft surface.
  • If you are replacing the display panel, you will need to transfer additional components from the old panel to the new one. Compare the back of the old display with the replacement display. Note all cables, sensors, and foam cushioning that are missing from the new display.
  • If there is a wire or cable underneath adhesive tape, always pull the tape off first. Do not pull on the cable directly.
  • If the cable is glued to the chassis, use a heated iOpener or a hair dryer to soften the adhesive first. You can then slide an opening pick underneath the cable to loosen it. Never pull on the delicate connectors.
  • Slide an opening pick underneath the foam cushion pieces to separate them from the display, and gently pull them off. You may need some double sided tape to re-attach them to the new display.
Insertar traducción aquí
