Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 17
We loosen a pair of Phillips screws to access the Lightning connector, pop its press connector off the back of the logic board, and seconds later it's free to leave this plastic mess behind. Luckily, the Lightning port is modular—so if you wear your port out, all you have to do is utterly destroy the case to replace that component. The logic board is secured with a lot of sticky tape.
  • We loosen a pair of Phillips screws to access the Lightning connector, pop its press connector off the back of the logic board, and seconds later it's free to leave this plastic mess behind.
  • Luckily, the Lightning port is modular—so if you wear your port out, all you have to do is utterly destroy the case to replace that component.
  • The logic board is secured with a lot of sticky tape.
Aflojamos un par de tornillos Phillips para acceder al conector Lightning, sacamos el conector de la prensa de la parte posterior de la placa lógica y, segundos después, es libre de dejar este desorden plástico.
Afortunadamente, el puerto Lightning es modular, por lo que si usa su puerto, todo lo que tiene que hacer es destruir el estuche para reemplazar ese componente.
La placa lógica está asegurada con una gran cantidad de cinta adhesiva.
