Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 16
The sync button is a self-contained li'l clicky dude, with contacts that match up to some spring contacts on the main board. Electrical switches can be complicated. This one, however, probably isn't. It is likely a pushbutton switch. A press of the button closes the circuit and lets current flow. This current will flow into the circuit and be interpreted as input. We told you it was simple. Electrical switches can be complicated. This one, however, probably isn't. It is likely a pushbutton switch. A press of the button closes the circuit and lets current flow. This current will flow into the circuit and be interpreted as input. We told you it was simple.
  • The sync button is a self-contained li'l clicky dude, with contacts that match up to some spring contacts on the main board.
  • Electrical switches can be complicated. This one, however, probably isn't. It is likely a pushbutton switch. A press of the button closes the circuit and lets current flow. This current will flow into the circuit and be interpreted as input. We told you it was simple.
El botón de sincronización es un tipo de clic independiente, con contactos que coinciden con algunos contactos de resorte en la placa principal.
Los interruptores eléctricos pueden ser complicados. Este, sin embargo, probablemente no lo es. Es probable que sea un interruptor de botón. Al presionar el botón se cierra el circuito y se deja fluir la corriente. Esta corriente fluirá hacia el circuito y se interpretará como entrada. Te dijimos que era simple.
