Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Paso 2
Line up the small SATA connectors so that the narrow side of the connector on the SSD matches the narrow side on the enclosure connector. Slide the drive in through the front of the enclosure until the SATA connector is fully seated. The SSD's ports connect with the enclosure in only one way. If the ports are not lining up, rotate the SSD and try again.
  • Line up the small SATA connectors so that the narrow side of the connector on the SSD matches the narrow side on the enclosure connector.
  • Slide the drive in through the front of the enclosure until the SATA connector is fully seated.
  • The SSD's ports connect with the enclosure in only one way. If the ports are not lining up, rotate the SSD and try again.
Insertar traducción aquí
