Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Traduciendo paso 2
Paso 2
Remove the T6 Torx screw securing the AirPort card to the logic board frame. The card will begin to tilt away from the iMac case as you remove the screw. Its final resting angle should be the angle at which it is removed and reinstalled.
  • Remove the T6 Torx screw securing the AirPort card to the logic board frame.
  • The card will begin to tilt away from the iMac case as you remove the screw. Its final resting angle should be the angle at which it is removed and reinstalled.
  • Remove the AirPort card by pulling it straight out of its socket.
Insertar traducción aquí
