Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 9 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 4
Paso 4
Use a plastic tool or your fingernails to carefully disconnect the orange headphone jack cable. Be sure to pull  straight up on the connector, not the cable itself. The headphone jack connector is unusually tall. When prying, be careful to not separate the lower, plastic part of the connector from the ribbon cable. Pry between the connector and the socket, not between the two halves of the connector.
  • Use a plastic tool or your fingernails to carefully disconnect the orange headphone jack cable. Be sure to pull straight up on the connector, not the cable itself.
  • The headphone jack connector is unusually tall. When prying, be careful to not separate the lower, plastic part of the connector from the ribbon cable. Pry between the connector and the socket, not between the two halves of the connector.
Insertar traducción aquí
