Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 3
If you don't need to pre-configure your hard drive, skip to step 5. If you're not sure or if the drive is used, it's a good idea to pre-configure your hard drive. Select "Disk Utility" from the menu and press [enter] or click the continue button.
  • If you don't need to pre-configure your hard drive, skip to step 5. If you're not sure or if the drive is used, it's a good idea to pre-configure your hard drive.
  • Select "Disk Utility" from the menu and press [enter] or click the continue button.
Si no necesitas pre-configurar tu disco duro, salta al paso 5. Si no estás seguro o si el disco duro es usado, es una buena idea pre-configurar el disco duro.
Selecciona "Utilidades del Disco" en el menú y presiona [enter] o haz clic en el botón de continuar.
