Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Inglés
Español
Paso 9
Once you've hit your desired amount of time that you want your controller shell to remain under the UV black light it's time to clean it one last time. I use the dish soap here for the same reasons mentioned in Step 7. Once the Salon Care 40 Volume Creme has been rinsed off the shell take a paper towel and dry the exterior.
Controller Shell Cleanup
  • Once you've hit your desired amount of time that you want your controller shell to remain under the UV black light it's time to clean it one last time. I use the dish soap here for the same reasons mentioned in Step 7.
  • Once the Salon Care 40 Volume Creme has been rinsed off the shell take a paper towel and dry the exterior.
  • Be gentle when washing the sticker so it doesn't become damaged.
  • If the sticker is on the back shell pat, DON'T RUB, the sticker dry. This will prevent you from causing any sort of damage to the wet label. Although the water beads may be dried up the label itself will be damp and to much pressure while rubbing it can cause damage.
Insertar traducción aquí
