Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 2
Paso 2
Now that the keyboard is outside of the laptop, you will see a ribbon cable coming from the back of the keyboard connected to the laptop. To detach this cable you must use the pointed edge of the spudger to press down on the locking mechanisms on each side. Do not use too much pressure when  disconnecting the ZIF connector.
  • Now that the keyboard is outside of the laptop, you will see a ribbon cable coming from the back of the keyboard connected to the laptop.
  • To detach this cable you must use the pointed edge of the spudger to press down on the locking mechanisms on each side.
  • Do not use too much pressure when disconnecting the ZIF connector.
  • After unlocking both sides of the ZIF connector remove the keyboard for replacement.
Insertar traducción aquí
