Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 4
Paso 4
Remove the four 3.70 mm Phillips #1 screws securing the motherboard to the lower case. Gently peel the front bezel off. Lift the motherboard out of the lower case.
  • Remove the four 3.70 mm Phillips #1 screws securing the motherboard to the lower case.
  • Gently peel the front bezel off.
  • Lift the motherboard out of the lower case.
  • If you are installing a new motherboard, make sure to transfer any remaining cables onto the new motherboard, as well as the CPU, RAM, modem, and Wi-Fi card.
Insertar traducción aquí
