Saltar al contenido principal
Inglés
Español
Traduciendo paso 8
Paso 8
Now, using a plastic opening tool, carefully insert it between the frame and the glass and force it slowly to remove the adhesive. You may also heat it to help. Now, Remove the rest of adhesive from the frame to better apply the new digitizer on it. Follow this backwards to reassemble the mobile.
  • Now, using a plastic opening tool, carefully insert it between the frame and the glass and force it slowly to remove the adhesive. You may also heat it to help.
  • Now, Remove the rest of adhesive from the frame to better apply the new digitizer on it.
  • Follow this backwards to reassemble the mobile.
Insertar traducción aquí
