Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Paso 5
The logic board is still connected to the front case by the display ribbon cable, located on the headphone jack side of the logic board. Lift the logic board assembly out of the front case from the click wheel connector side (the cable you just disconnected).  Rotate the logic board assembly about the display ribbon cable and lay it next to the front case.
  • The logic board is still connected to the front case by the display ribbon cable, located on the headphone jack side of the logic board.
  • Lift the logic board assembly out of the front case from the click wheel connector side (the cable you just disconnected). Rotate the logic board assembly about the display ribbon cable and lay it next to the front case.
Insertar traducción aquí
