Inglés
Español
Traduciendo paso 3
Paso 3
Slide the pointed end of the spudger into the slot under the upper right corner of the ear speaker and gently pry upwards. Be careful during this step, as the upper portion of the speaker can easily detach from the lower portion, causing the coil inside to unwind. Be sure to pry the entire assembly up.
  • Slide the pointed end of the spudger into the slot under the upper right corner of the ear speaker and gently pry upwards.
  • Be careful during this step, as the upper portion of the speaker can easily detach from the lower portion, causing the coil inside to unwind. Be sure to pry the entire assembly up.
  • Lift the ear speaker up and out of the device.
Insertar traducción aquí
