Saltar al contenido principal
Inglés
Español
Paso 2
Use the flat end of a spudger to pry up the right side of the ear speaker cover assembly. Do not try to pry the assembly all the way off, as it is still connected at two points. Turn the spudger around and use the pointed side to detach the two clips securing the top of the assembly.
  • Use the flat end of a spudger to pry up the right side of the ear speaker cover assembly.
  • Do not try to pry the assembly all the way off, as it is still connected at two points.
  • Turn the spudger around and use the pointed side to detach the two clips securing the top of the assembly.
  • Once the clips are detached, lift the cover assembly up from the device.
Insertar traducción aquí
