Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 3
Remove the two 2.5 mm Phillips screws from the back of the power switch mechanism.
  • Remove the two 2.5 mm Phillips screws from the back of the power switch mechanism.
  • You can then push in on the power switch (on the exterior of the iPad) to push the mechanism's internal metal plate loose.
  • You can then peel the PMV cable free from the iPad's case, working backwards from the power switch towards the mute switch.
  • Lift free the small metal frame piece supporting the mute and volume switches.
  • Note: The photo shows the mute and volume switch frame being removed before the rear camera and power switch; this is possible but it's probably best to start with the power switch first.
Insertar traducción aquí
