Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 5
Remove the following 9 screws and 2 nuts from the heat sink:
  • Remove the following 9 screws and 2 nuts from the heat sink:
  • Four 3 mm Phillips from around the fan and the heat sink bracket. The bracket can also be removed at this point.
  • One 11.5 mm (left) and one 4.5 mm (right) Phillips from the plastic fingers of the hinge grill.
  • One 4.5 mm Phillips at the top right corner of the heat sink.
  • Two 6 mm Phillips on the lower left corner and face of the heat sink.
  • Two 4 mm screw nuts with attached springs from either side of the heat sink.
Insertar traducción aquí
