Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 4 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 6
Paso 6
Pull up on the motherboard and display. It is glued to the base so it will require a little force. Be careful though, as the board is fragile. Pull up on the motherboard and display. It is glued to the base so it will require a little force. Be careful though, as the board is fragile. Pull up on the motherboard and display. It is glued to the base so it will require a little force. Be careful though, as the board is fragile.
  • Pull up on the motherboard and display. It is glued to the base so it will require a little force. Be careful though, as the board is fragile.
Insertar traducción aquí
