Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 14 guías que incluyan este paso.
Inglés
Español
Paso 6
If present, peel the piece of black tape covering the hidden screw near the power button. Remove the 2.6 mm Phillips screw securing the logic board near the power button.
  • If present, peel the piece of black tape covering the hidden screw near the power button.
  • Remove the 2.6 mm Phillips screw securing the logic board near the power button.
  • (Use caution when removing this screw and removing the power contact held by it; the contact tab will come loose with the screw)
  • Notice the small rubber bumper under the screen & digitizer cables (which are detached at top above the Q-code). This bumper can fall off of the logic board when removed or get stuck to the cables and fall off later.
Insertar traducción aquí
