Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Remove the two 1.6 mm Phillips screws securing the power button bracket to the outer case. Take extra care with the display cables, which can prevent easy access to the right-hand screw. The cables are easily damaged.
  • Remove the two 1.6 mm Phillips screws securing the power button bracket to the outer case.
  • Take extra care with the display cables, which can prevent easy access to the right-hand screw. The cables are easily damaged.
  • Slightly pull the power button bracket away from the outer case.
Insertar traducción aquí
