Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 20 guías que incluyan este paso.
Inglés
Español
Paso 5
Insert the edge of a plastic opening tool between the battery and the outer case near the bottom of the iPhone. Run the plastic opening tool along the right edge of the battery and pry up at several points to completely separate it from the adhesive securing it to the outer case.
  • Insert the edge of a plastic opening tool between the battery and the outer case near the bottom of the iPhone.
  • Run the plastic opening tool along the right edge of the battery and pry up at several points to completely separate it from the adhesive securing it to the outer case.
  • If the adhesive is too strong, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery.
  • Wait about one minute for the alcohol solution to weaken the adhesive.
  • Use the flat end of a plastic opening tool to gently lift the battery.
  • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
  • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
Inserta el borde de una herramienta de apertura de plástico entre la batería y la carcasa exterior cerca del borde inferior del iPhone.
Corre la herramienta de apertura de plástico junto el borde derecho de la batería y has palanca en varios puntos para separar completamente del adhesivo asegurándola a la carcasa exterior.
Si el adhesivo es muy fuerte, aplica unas gotas de alcohol isopropílico de alta concentración (mayor al 90%) debajo el borde de la batería.
Espera por alrededor de un minuto para que el alcohol debilite el adhesivo.
Usa el lado plano de una herramienta de apertura de plástico para levantar gentilmente la batería.
No trates de levantar forzosamente la batería. Si es necesario, aplica unas gotas mas de alcohol para debilitar aun mas el adhesivo. Nunca deformes o perfores la batería con tu herramienta de palanca.
Si hay algún resto de alcohol en el teléfono, límpialo cuidadosamente o deja que seque antes de instalar tu batería nueva.
