Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Español
Paso 11
Whether installing a replacement display assembly or re-using the existing display assembly, note the following: Carefully straighten the digitizer and LCD data cables, and feed them through the slot cut in the outer case. The middle photo shows the digitizer cable being correctly fed through to its full length.
Display Assembly Installation (Cont'd)
  • Whether installing a replacement display assembly or re-using the existing display assembly, note the following:
  • Carefully straighten the digitizer and LCD data cables, and feed them through the slot cut in the outer case.
  • The middle photo shows the digitizer cable being correctly fed through to its full length.
  • This photo shows the display assembly being installed incorrectly, with too much slack in the digitizer cable, which then forms a bend/loop that gets caught in the slot. The third photo also shows this loop.
  • If the digitizer cable has been installed incorrectly, it will not reach its socket on the logic board. Do not attempt to pull it through by force, or it will be cut by the sharp edge of its slot in the enclosure. Remove the display assembly, straighten the cable, and re-feed the cable through completely and correctly.
Insertar traducción aquí
