Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Traduciendo paso 1
Paso 1
After disassembling the handset, you will see the inner components of the handset. Locate the rubber part towards the very bottom of the handset. This is the microphone with protective rubber cover.
  • After disassembling the handset, you will see the inner components of the handset.
  • Locate the rubber part towards the very bottom of the handset. This is the microphone with protective rubber cover.
  • Remove the protective rubber cover. This may require a spudger.
  • The microphone is exposed upon removal of the protective rubber cover. Avoid contact with water.
Insertar traducción aquí
