Saltar al contenido principal
Inglés
Español
Paso 17
Avoid placing any portion of the adhesive over the following areas: Tooling holes on the left and right upper corners.
  • Avoid placing any portion of the adhesive over the following areas:
  • Tooling holes on the left and right upper corners.
  • Camera.
  • EMI Pad
  • On the flange of the display assembly:
  • Apply the 6mm x 120mm strip, red side up, to the area on the flange between the EMI pad and the adhesive strip on the left side.
  • Apply the 6mm x 30mm strip, red side up, to the area on the flange between the EMI pad and the camera.
  • Apply the 6mm x 155mm strip, red side up, to the area on the flange between the camer and the adhesive strip on the right side.
Insertar traducción aquí
