Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 2
Locate an easy point of access for a spudger, and then slowly insert it into the gap and pry it open. The opening should become bigger if you exert force at a 30 degrees angle.
  • Locate an easy point of access for a spudger, and then slowly insert it into the gap and pry it open.
  • The opening should become bigger if you exert force at a 30 degrees angle.
  • Increase the degree of slant until the back cover is completely removed.
Insertar traducción aquí
