Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 20
We'll skip tearing down the display itself—we've been down that road before—so how about a lovely X-ray instead? Here you can see the camera board with its long data cable, the solid metal Apple logo, and even the little magnets  embedded in the lid for sleep/wake functionality. We gently detach the gutted shell of the keyboard/upper case from the display, and take a closer look at the fancy new hinge system. Sometimes seemingly standard hardware deserves an Ooh and an Ahh: These small, precision hinges are likely injection molded, allowing for thinner and more precise parts.
  • We'll skip tearing down the display itself—we've been down that road before—so how about a lovely X-ray instead? Here you can see the camera board with its long data cable, the solid metal Apple logo, and even the little magnets embedded in the lid for sleep/wake functionality.
  • We gently detach the gutted shell of the keyboard/upper case from the display, and take a closer look at the fancy new hinge system.
  • Sometimes seemingly standard hardware deserves an Ooh and an Ahh: These small, precision hinges are likely injection molded, allowing for thinner and more precise parts.
  • More importantly, more complex parts can be produced with less waste than traditional machining, which in our book makes it a win.
Omitiremos desmontar la pantalla (ya hemos recorrido esecamino antes). Entonces, ¿qué tal una radiografía encantadora? Aquí puedes ver la placa de la cámara con su cable de datos largo, el logotipo de Apple de metal sólido e incluso los pequeños imanes incrustados en la tapa para la funcionalidad de dormir/despertar.
Con cuidado separamos la carcasa del teclado/ mayúsculas de la pantalla y observamos de cerca el nuevo y elegante sistema de bisagras.
A veces el hardware aparentemente estándar merece una exclamación de admiración: es probable que estas pequeñas bisagras de precisión estén moldeadas por inyección, lo que permite partes más delgadas y más precisas
Más importante aún, se pueden producir partes más complejas con menos desperdicio que el mecanizado tradicional, lo que para nosotros es una victoria.
