Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 4 guías que incluyan este paso.
Inglés
Español
Paso 2
Use a Phillips #0  driver to unscrew the eight 10mm screws. Remove the base ring after unscrewing all the screws. Be careful when lifting the base ring from the Furby. There are sharp edges that hold the base ring in place.
  • Use a Phillips #0 driver to unscrew the eight 10mm screws.
  • Remove the base ring after unscrewing all the screws.
  • Be careful when lifting the base ring from the Furby. There are sharp edges that hold the base ring in place.
Insertar traducción aquí
