Inglés
Español
Paso 4
Using a 1.5mm Hex screwdriver, remove 3.0 mm hex screw on top edge of silver panel. Using a Phillips #00 screwdriver, remove the 3.0 mm screw on bottom edge. Once both screws are removed the silver side casing will slide off.
  • Using a 1.5mm Hex screwdriver, remove 3.0 mm hex screw on top edge of silver panel.
  • Using a Phillips #00 screwdriver, remove the 3.0 mm screw on bottom edge.
  • Once both screws are removed the silver side casing will slide off.
Insertar traducción aquí
