Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Paso 2
Starting with the battery cell closest to the dock connector, run a plastic opening tool underneath the edge of the battery closest to the logic board void to make enough room to insert the flat end of a spudger Run the flat end of a spudger along the two long sides of each battery cell to completely separate them from the adhesive securing them to the rear case.
  • Starting with the battery cell closest to the dock connector, run a plastic opening tool underneath the edge of the battery closest to the logic board void to make enough room to insert the flat end of a spudger
  • Run the flat end of a spudger along the two long sides of each battery cell to completely separate them from the adhesive securing them to the rear case.
  • If the adhesive is very difficult to separate, reheat the rear panel and try again.
Insertar traducción aquí
