Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 3 guías que incluyan este paso.
Inglés
Español
Paso 3
Use a plastic opening tool to help remove the piece of tape covering the end of the dock connector cable. Use the edge of a plastic opening tool to carefully pry the dock connector cable's connector up from its socket on the logic board. Peel the dock connector ribbon cable off the rear panel.
  • Use a plastic opening tool to help remove the piece of tape covering the end of the dock connector cable.
  • Use the edge of a plastic opening tool to carefully pry the dock connector cable's connector up from its socket on the logic board.
  • Peel the dock connector ribbon cable off the rear panel.
Insertar traducción aquí
