Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Paso 4
Using a Phillips #00 screwdriver, remove the following screws: Four 5mm wide grey Phillips screws on the logic board. One of the 5mm screws is hidden under the circular white tape in the center of the logic board.
  • Using a Phillips #00 screwdriver, remove the following screws:
  • Four 5mm wide grey Phillips screws on the logic board.
  • One of the 5mm screws is hidden under the circular white tape in the center of the logic board.
  • Seven 3mm small grey Phillips screws (four on one side, three on the other) from the black side casing.
Insertar traducción aquí
