Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 153 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 23
Paso 23
Holding the iPad by the top and bottom right corners, rotate the front glass away from the iPad. Be careful of any adhesive that may still be attached, and use an opening pick to cut any adhesive that may still be holding the front panel down.
  • Holding the iPad by the top and bottom right corners, rotate the front glass away from the iPad.
  • Be careful of any adhesive that may still be attached, and use an opening pick to cut any adhesive that may still be holding the front panel down.
  • During reassembly use a microfiber cloth and compressed air to clean any dust or fingerprints off the LCD before reinstalling the glass.
Sosteniendo el iPad por las esquinas superior e inferior derecha, gire el cristal delantero lejos del iPad.
Tenga cuidado con cualquier adhesivo que todavía pueda estar unido, y utilice un cepillo de apertura para cortar cualquier adhesivo que aún pueda sostener el panel frontal hacia abajo.
[* black] Holding the iPad by the top and bottom right corners, rotate the front glass away from the iPad.
[* icon_caution] Be careful of any adhesive that may still be attached, and use an opening pick to cut any adhesive that may still be holding the front panel down.
[* icon_reminder] During reassembly use a microfiber cloth and compressed air to clean any dust or fingerprints off the LCD before reinstalling the glass.
