Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Paso 3
Rotate the device so that the front is facing you.
  • Rotate the device so that the front is facing you.
  • Unplug the four pin header from its socket on the motherboard. The wires on the header are these colors: brown, red, orange, and yellow.
  • Use a tweezer if you find it hard to pull this header out with your fingers.
  • Gently pull out the ribbon cable from its socket.
  • Pay attention to the orientation of the header and the ribbon cable. Replacing the base the wrong way may short circuit the board.
Insertar traducción aquí
