Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Remove the 10mm chrome screw from the antenna base with the Phillips PH1 screwdriver.  Remove the antenna base from the casing. This red wire will now be loose and you can  move it out of the antenna base slot.
  • Remove the 10mm chrome screw from the antenna base with the Phillips PH1 screwdriver. Remove the antenna base from the casing.
  • This red wire will now be loose and you can move it out of the antenna base slot.
Insertar traducción aquí
