Saltar al contenido principal
Inglés
Español
Paso 6
Remove the bridge pin to free the other side of the string. Sometimes, you need to take the picture slightly differently than you would actually perform the task. Some things are impossible to show the actual action. Removing a bridge pin takes some force wiggling back and forth, which you can't show in a picture. In this case, we removed the pin ahead of time, then put it back for the picture.
  • Remove the bridge pin to free the other side of the string.
  • Sometimes, you need to take the picture slightly differently than you would actually perform the task. Some things are impossible to show the actual action.
  • Removing a bridge pin takes some force wiggling back and forth, which you can't show in a picture. In this case, we removed the pin ahead of time, then put it back for the picture.
  • It's more important to show the 'goal' of the shot than the actual action. In this case, pulling the pin partially out shows the viewer what the complete pin looks like, even though the task is essentially complete by the time the photo is taken.
  • Make sure that your hand (or any other object) does not interfere with the action being performed.
Retira el pasador del puente para liberar el otro lado de la cuerda.
A veces, es necesario tomar la foto de forma ligeramente diferente a como se realizaría la tarea en realidad. Algunas cosas son imposibles de mostrar la acción real.
Quitar el pasador del puente requiere un poco de fuerza para moverlo de un lado a otro, lo que no se puede mostrar en una foto. En este caso, hemos quitado el pasador con antelación y luego lo hemos vuelto a poner para la foto.
Es más importante mostrar el "objetivo" de la toma que la acción real. En este caso, sacar el alfiler parcialmente muestra al espectador el aspecto del alfiler completo, aunque la tarea esté esencialmente terminada en el momento de tomar la foto.
Asegúrate de que tu mano (o cualquier otro objeto) no interfiera con la acción que se está realizando.
