Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 33
Pour a small amount of the plastic beads that were included with the kit into a heat- and stick-resistant container. Use a heat gun to heat the plastic beads until they turn transparent. Most hair driers are also capable of melting the beads. If neither a hair drier of sufficient power nor a heat gun are available to you, you can also try boiling them and straining them out of the boiling water.
  • Pour a small amount of the plastic beads that were included with the kit into a heat- and stick-resistant container.
  • Use a heat gun to heat the plastic beads until they turn transparent.
  • Most hair driers are also capable of melting the beads. If neither a hair drier of sufficient power nor a heat gun are available to you, you can also try boiling them and straining them out of the boiling water.
  • When using a heat gun or hair dryer, be sure to turn the heat to high but leave the fan on low, or you will blow the beads out of the container!
Insertar traducción aquí
